3 members (TexasA&M48Truck, Bill Hanlon, 52Carl), 94 guests, and 2 robots.
Topics128,094
Posts1,056,058
Members48,433
Bought a 72 Boler trailer this afternoon and planning to tow it with my 55 second series. Trailer is fairly light and should be under 1200lbs loaded. Anyone know of an aftermarket universal assembly that is a relatively easy bolt in? I have the rear non step bumper and would like to somehow have the receiver exit below it. Looking at the universal versions at Princess Auto here in Canada but suspect somebody as adapted something.
1955 Chevy 3100
rease hitches will have something for you
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
are you coming to the BC 'Bolters Museum tour on March 7th?
See Gabfest/Events Listing....
Welcome to the 'bolt!
GMC: Get More Cash...
1958 GMC
My Webshots photos
I'm runnibg a draw tite. Pretty easy install except for the spare carrier.
This is exactly what I am looking for. Can you give me more info as in part number?
1955 Chevy 3100
I was not aware of the tour...can you pm with some more info?
1955 Chevy 3100
I got my drawtie off craigslist. Don't have a part number, but it is probably the same one listed for 63- 90? chevy pickups. The frame rails are 34 inches apart. It fit like a glove.
should be a 75034 i believe ! from drawtite
75034 - Old dog is correct!
Thanks for the info and now on the hunt!
1955 Chevy 3100
Jim & Caroline
That # isn't a drawtite #, I just checked...
I want one for my '58 1/2 ton.....
after some research, it's a Hidden Hitch # for a 67-87 chevy shortbox
other than drilling, any install issues I should be aware of?
1958 GMC
My Webshots photos
I want one for my '58 1/2 ton.....after some research, it's a Hidden Hitch # for a 67-87 chevy shortbox
I couldn't find my invoice, so I took the number directly off of the hitch. I believe it should be correct.
Not really. The hardest part was fitting the spare carrier if you have one under there.
Bought a universal unit this afternoon at our local tool/farm supply store, Princess Auto, which I believe is Canadian only. I had to enlarge one frame hole and drill 2 more at 1/2 inch for the mounting plates. The receiver part is adjustable but not to the dimension I need so will need 2 spacer plates approximately 5/8" to make up the difference. Had to remove the spare tire and holder and after I mount everything will see if I can fit it back in. Receiver opening should sit fairly close to the bottom of the bumper and slightly behind towards the differential. I will post some pictures of the final install.
1955 Chevy 3100
That is a draw-tite part number according to this site: http://www.etrailer.com/hitch-1963_Chevrolet_Pickup%20with%208%20ft.%20Bed.htm
Interestingly, if you go to the instructions page it says "Towing Products, Plymouth, MI", which may or may not be associated with Draw-Tite. Probably Hidden-hitch and Drawtite are brandnames of the same parent co.
No affiliation, but I have ordered lots of stuff from etrailer.com and they are fast and accurate....
R-Bo
1966 GMC 305V6 in the family
Spent the day installing the receiver assy. and it turned out much better then expected. Temporarily installed everything for fitment and after moving the spare tire assembly fwd 4 1/2 inches, it will all work. The nice thing about this assy. is that the tubing curves from the brackets that bolt to the frame, to the bumper, thus allowing the spare tire carrier to fit. After looking at several different manufacturers, ie. Drawtite, all were straight, which did not allow the clearance.
I need to trim some of the brackets, and clean up the spacers before final installation. The receiver receptacle sits slightly below the bumper and just forward of the bottom edge towards the differential. Once I black out all the bolts and nuts, and with the license plate in place, it will be hardly noticeable, which was a major concern for me.
For those interested, here are the specifications from the Princess auto flyer for this week.
• Class III multi-fit hitch
receiver made by Bully
• Fits Chevy, Ford, Dodge, GMC and
Toyota light duty trucks.
• 500 lbs. max. tongue weight, 5,000 lbs.
max. gross tow weight
• No welding required
Wt. 56.8 lbs.
P/N 8253940 $88.88
Have some pictures but not able to figure out how to post them.
1955 Chevy 3100
I'll have to check princess auto out.
1958 GMC
My Webshots photos
