3 members (Bill Hanlon, Erniegp, festerhairball), 86 guests, and 2 robots.
Topics128,054
Posts1,055,781
#509540 02/24/2009 12:13 AM
i rebuilt a 230 about 8000 miles ago and recentlyi had a cylinder wall go out got a hole the size of my thumb in number 5 going less than 10 mph is it feasablt to try again or just locate a new engine
Former Workshop Owner
It sounds like you need a new block at the very least. This will get more responses in the Engine & Driveline forum. So let's get this moved.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
J Lucas #509646 02/24/2009 3:27 AM
For such a common engine you'd be best to find another.
On rare and hard to find or expensive engines sleeving is an option, and preferably if you sleeve one cylinder you sleeve them all, but it's not always done that way.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #509661 02/24/2009 3:41 AM
so was it sleeved already and that failed??? wonder what caused it?
Unless the hole is within 1/2" of the top or bottom of the cylinder, go ahead and sleeve it. What caused the hole- - - -maybe a broken rod or something similar? That's a very unusual failure unless something comes totally unglued.
Have your machinist use a heavy-duty sleeve, one with a 1/8" wall thickness, not 3/32" like would normally be used to recondition a cylinder. I've sleeved race engines with holes a couple of inches in diameter in a cylinder, and got normal performance out of them.
230's have a nasty habit of developing cracks in the block along the lifter bores, so if you've got a block that's OK in that area, better hang onto it and patch that cylinder.
I've got a complete 230 just sitting here if you want it. Ran when I pulled it, been under cover ever since,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Apprentice
Apprentice
if it was just a weak cyl. wall that let go i would sleave it. you can also use a 250 block as the only differince between a 250 and a 230 is the stroke. so your 230 parts would fit right in a 250 block.
magnafluxed the block it is shot found a 63 230 complete so im using it instead thanks for the input
