4 members (greenie-reddy, pauld, 2 invisible), 85 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#509544 02/24/2009 12:25 AM
Hello all,
I joined the older chevy truck world in a double way
1 - a 1955 stepside sidemount spare 2nd series 3200 with 265 & three on tree - original and not in terrible shape - motor runs fine some smoke - hadn't ran in 2 years or driven in 7 - needed carb kit, fuel pump and all new brakes - it doesn't have a oil filter - is this a big item or just need to change oil more often - I'm going to change all fluids - water, oil, trans, rear end, brake and put truck back on road somewhat limited of course.
2 - a 1966 stepside sidemount spare which is in much worse shape body wise - quite a bit of rust but truck runs - v8 not original, 3spd with floor shift and non stock wheels & tires.
Is either of these trucks very rare?
Am I crazy to put a cheap paint job on the 55 and drive, show and not worry about having to keep the body perfect? Any help or ideas appreciated.
ernie22 #509608 02/24/2009 2:30 AM
Former Workshop Owner
No you are not crazy, it's all about what makes you happy.
Welcome to the "Bolt".
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
J Lucas #509643 02/24/2009 3:23 AM
A big welcome to the bolt. You'll fit right in even though some may be jealous that you have TWO bolts smile
Achipmunk #509722 02/24/2009 5:21 AM
Everything sounds perfectly normal to me & you fit in here just fine dance
Welcome to the 'bolt, ernie22 cool
It's probably a good idea to have an oil filter but my '54 doesn't have one (never did) & it's okay.
I don't know if either of the trucks are rare, I sort of doubt it.
A cheap coat of paint was what my dad put on my truck every couple of years as routine maintenance & it kept it protected, that's what's important.
Sabrina
'54 3100
MexicoSab #509814 02/24/2009 4:10 PM
Sounds like a very intelligent decision to me, Welcome!!!
