1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 13 New Guy | | New Guy Joined: Apr 2005 Posts: 13 | i rebuilt a 230 about 8000 miles ago and recentlyi had a cylinder wall go out got a hole the size of my thumb in number 5 going less than 10 mph is it feasablt to try again or just locate a new engine | | | | | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | It sounds like you need a new block at the very least. This will get more responses in the Engine & Driveline forum. So let's get this moved.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | For such a common engine you'd be best to find another.
On rare and hard to find or expensive engines sleeving is an option, and preferably if you sleeve one cylinder you sleeve them all, but it's not always done that way.
Grigg | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | so was it sleeved already and that failed??? wonder what caused it? | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Unless the hole is within 1/2" of the top or bottom of the cylinder, go ahead and sleeve it. What caused the hole- - - -maybe a broken rod or something similar? That's a very unusual failure unless something comes totally unglued.
Have your machinist use a heavy-duty sleeve, one with a 1/8" wall thickness, not 3/32" like would normally be used to recondition a cylinder. I've sleeved race engines with holes a couple of inches in diameter in a cylinder, and got normal performance out of them.
230's have a nasty habit of developing cracks in the block along the lifter bores, so if you've got a block that's OK in that area, better hang onto it and patch that cylinder. Jerry
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've got a complete 230 just sitting here if you want it. Ran when I pulled it, been under cover ever since, Scott | | | | | Joined: Feb 2009 Posts: 35 Apprentice | | Apprentice Joined: Feb 2009 Posts: 35 | if it was just a weak cyl. wall that let go i would sleave it. you can also use a 250 block as the only differince between a 250 and a 230 is the stroke. so your 230 parts would fit right in a 250 block. | | | | | Joined: Apr 2005 Posts: 13 New Guy | | New Guy Joined: Apr 2005 Posts: 13 | magnafluxed the block it is shot found a 63 230 complete so im using it instead thanks for the input | | |
