0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 9 New Guy | | New Guy Joined: Feb 2009 Posts: 9 | Hello all, I joined the older chevy truck world in a double way 1 - a 1955 stepside sidemount spare 2nd series 3200 with 265 & three on tree - original and not in terrible shape - motor runs fine some smoke - hadn't ran in 2 years or driven in 7 - needed carb kit, fuel pump and all new brakes - it doesn't have a oil filter - is this a big item or just need to change oil more often - I'm going to change all fluids - water, oil, trans, rear end, brake and put truck back on road somewhat limited of course. 2 - a 1966 stepside sidemount spare which is in much worse shape body wise - quite a bit of rust but truck runs - v8 not original, 3spd with floor shift and non stock wheels & tires. Is either of these trucks very rare? Am I crazy to put a cheap paint job on the 55 and drive, show and not worry about having to keep the body perfect? Any help or ideas appreciated.
| | | | | Joined: Nov 2004 Posts: 2,432 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,432 | No you are not crazy, it's all about what makes you happy.
Welcome to the "Bolt".
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | A big welcome to the bolt. You'll fit right in even though some may be jealous that you have TWO bolts  | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Everything sounds perfectly normal to me & you fit in here just fine Welcome to the 'bolt, ernie22  It's probably a good idea to have an oil filter but my '54 doesn't have one (never did) & it's okay. I don't know if either of the trucks are rare, I sort of doubt it. A cheap coat of paint was what my dad put on my truck every couple of years as routine maintenance & it kept it protected, that's what's important. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Sounds like a very intelligent decision to me, Welcome!!! | | |
