4 members (klhansen, FAST55, 69Cuda, dt235sd), 120 guests, and 5 robots.
Topics128,050
Posts1,055,667
#50911 10/06/2005 12:10 PM
Doe's anyone have any idea what is causing a Crunching, Grinding noise in my front right wheel when I make a right turn? I lifted the truck up and the wheels turn nice with no proublem or noise. Pulled both wheels off and they looked good, greased them up and reinstalled them. Seems to have started after I greased all the zerk fittings. Any help, like always, is verrrrry much app. Paul
PJP
#50912 10/06/2005 12:50 PM
When it was up did you grab the two sides of the tire and shake it back and forth?? Any play could indicate bad wheel bearings... and the crunching grinding sound means they're beyond shot... How about your king pins??
Larry Bear
55.5 Chevy 3100 Panel
#50913 10/06/2005 2:33 PM
Sounds like a wheel bearing to me, but it could be a "Front End" problem (ie kingpins, et cetera)
Are your brakes Disc or Drum? I've had discs do that to me before. If you've got crunching, though, you'll probably need a new rotor.
#50914 10/06/2005 6:52 PM
Berrings are in great shape, will check the king pins, and roters thanks Paul
PJP
