| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50911 10/06/2005 12:10 PM | Joined: Jun 2005 Posts: 50 Member | | Member Joined: Jun 2005 Posts: 50 | Doe's anyone have any idea what is causing a Crunching, Grinding noise in my front right wheel when I make a right turn? I lifted the truck up and the wheels turn nice with no proublem or noise. Pulled both wheels off and they looked good, greased them up and reinstalled them. Seems to have started after I greased all the zerk fittings. Any help, like always, is verrrrry much app. Paul
PJP
#50912 10/06/2005 12:50 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | When it was up did you grab the two sides of the tire and shake it back and forth?? Any play could indicate bad wheel bearings... and the crunching grinding sound means they're beyond shot... How about your king pins?? | | |
#50913 10/06/2005 2:33 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Sounds like a wheel bearing to me, but it could be a "Front End" problem (ie kingpins, et cetera)
Are your brakes Disc or Drum? I've had discs do that to me before. If you've got crunching, though, you'll probably need a new rotor. | | |
#50914 10/06/2005 6:52 PM | Joined: Jun 2005 Posts: 50 Member | | Member Joined: Jun 2005 Posts: 50 | Berrings are in great shape, will check the king pins, and roters thanks Paul
PJP
