| | | Forums66 Topics128,139 Posts1,056,756 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50881 10/05/2005 4:07 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | I have 235 motor out of a 62 chevy in my 54. I have split the original manifold for duel exhausts. I am considering purchasing 2 x 1 intake. Will the 2 x 1 intake manifold fit with the old exhaust manifold?
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#50882 10/05/2005 8:51 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Some will, some won't. I'm sure others here can give you a better list. I think the offy will. However, it is an aluminum intake and will carbonize eventually from the exhaust heat. Some say that it is better to heat an aluminum intake with water. A vintage cast iron intake like the old edelrock or tattersfield will mate right up with your old exhaust mainifold. The old edmunds will not and is already set up to be water heated. | | |
#50883 10/06/2005 1:13 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Any aftermarket alum. intake SHOULD theoretically bolt up to you stock exhaust, but in reality, many WON'T. The heat riser flange angle won't be right to match up to the exhaust and will need to be milled. If too much material is already gone, a thin spacer will need to be made to take up the gap.
The idea is to get the intake and exhaust manifolds bolted together tight (with a gasket in between), and still have the (3) alignment rings on the intake ports line up and the studs on the ends of the ends of the exhaust manifold line up. Easier said than done sometimes. | | |
