3 members (2-Ton, kbenz, MNSmith), 161 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#508707 02/21/2009 11:10 PM
I have a 48 chevy truck and wish to put a small block chevy in it. How do you set up the drive train on a straight axle small block conversion. classic performance says that the tail shaft of the transmission should be set at 4 degrees downward and the pinion angle at 2-3 degrees upward. Also how do I center the motor and find the corresct placement I guess all I can do is measure,measure measure. should I just use the bolt in mustang 2 crossmember with the engines mounts installed and use their transmission crossmember. i am doing a budget build. I will be using a 305 chevy for the motor and the truck will be in black primer. any suggestions?
This Tech Tip will lead you to all the information you'll ever need to know about driveshafts and their angles.
http://www.stovebolt.com/techtips/driveline/setup/index.html
The short answer is put the engine in any how you want to so long as it's straight in the frame front to back, not sitting sideways. Then match your pinion angle to your transmission output shaft angle.
So long as the engine oils its self properly it makes no difference what angle the engine sit at in relation to the ground or the truck frame (within reason). They key is matching the angle of the rear axle pinion to the engine/transmission.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
