10 members (sparky46, LAROKE, Otto Skorzeny, Gdads51, Woogeroo, Shade Baby, 68ironhead, Jon G, Wally / Montana, 3B),
162
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,104 Posts1,056,197 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 46 | I have a 48 chevy truck and wish to put a small block chevy in it. How do you set up the drive train on a straight axle small block conversion. classic performance says that the tail shaft of the transmission should be set at 4 degrees downward and the pinion angle at 2-3 degrees upward. Also how do I center the motor and find the corresct placement I guess all I can do is measure,measure measure. should I just use the bolt in mustang 2 crossmember with the engines mounts installed and use their transmission crossmember. i am doing a budget build. I will be using a 305 chevy for the motor and the truck will be in black primer. any suggestions? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | This Tech Tip will lead you to all the information you'll ever need to know about driveshafts and their angles. http://www.stovebolt.com/techtips/driveline/setup/index.htmlThe short answer is put the engine in any how you want to so long as it's straight in the frame front to back, not sitting sideways. Then match your pinion angle to your transmission output shaft angle. So long as the engine oils its self properly it makes no difference what angle the engine sit at in relation to the ground or the truck frame (within reason). They key is matching the angle of the rear axle pinion to the engine/transmission. Grigg | | |
