6 members (Donf, tclederman, Shade Baby, TUTS 59, Chip O, Wayne67vert), 80 guests, and 6 robots.
Topics128,188
Posts1,057,218
Members48,465
I want to install a 350 V8 and a 5- or better yet a 6-speed manual tranny in my 55 Chevy pickup 1/2 ton NAPCO. It has a divorced transfer case, so I can shorten or lengthen the drive shaft. But I would prefer to find one that is similar in length as the original tranny. Any suggestions? Thanks. Michael
1 Offline
maybe one of the new process 5 speeds out of newer chevy trucks. like a nv3500 or nv4500.
2003 ford lightning
1959 chevy 36
Didn't Corvettes have six speeds and 350s until not too long ago?
I don't know how well a 'Vette tranny will work in a truck, but it will probably mount to the bell housing...
You might want to find one out of a C3 or a [very] early C4, if you give it a try. Anything newer will have too much electrical BS to mess with.
Wait...
Does your 55 have 4wd?
If it does, the 'vette option probably won't do it.
You can put any transmission you want in front of a divorced transfer case. That said, you still can't use a Corvette T56 for a number of reasons.
1954 GMC De Luxe COE
DJ Offline
You can use the early c-4 but i would not. They were not very good and broke a lot. We have the new tremec 6 speed in a 57 but i would not do it again.The tremec 5 speed is a better box for the street. 6 speed is more road race set up. Save your pennies they are not cheap,but you can have the shifter about anywere you want.
[shrug]
Just a suggestion.
I did say that I didn't know if it would work.
[puts 'Vette tranny on list of stuff that won't work]
The Camaro/Firebird T56 could be adapted to work. The Corvette is a weird configuration.
