Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Wickedbass), 33 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#508708 02/21/2009 11:12 PM
how hard is it to replace the wiring in my 48 chevy truck. I will be using a small block motor and have found wiring harnesses from $125 on up. What do I need to plan for? This will be a low budget build truck.
48 chevy truck dude #508741 02/22/2009 12:46 AM
It's not that hard but I found it very time consuming. Routing and hiding wires takes some thinking ahead. You also want to secure them and avoid abrasion. Gauges,switches,fuel sender,etc. all take time. Also grounding is very critical. I guess it's like anything else, you might as well spend a little more time, do it right and make it look good.
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
wahoo40 #508807 02/22/2009 3:40 AM
Ditto. It's not that hard. I did my '49 a couple of months ago. I'm guessing it took me 30 or 40 labor hours and this was my first time. Every device needs a good ground, and that's usually the hard part.
