7 members (GRNHydra, Forty9, Shardean, Ponchogl, SWEET, 78buckshot, Stovebolt48),
77
Mod | | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1 Junior Member | | Junior Member Joined: Dec 2003 Posts: 1 | I just bought a 46 Chevy truck with a 216 in it. The guy who had previously owned it said he was driving it and while driving it he heard a loud snap and then the engine started running ruff and would not idle. After the loud snap he said it made a thumping noise  . He told me that when he would put the air breather on the carb it would muffle the sound. He has not ran the truck for over 5 years since that happend. I recently purchased the truck and I would like to fix the origanl motor were should I start. Thanks | | | | | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | Pull off the valve cover, pushrod cover, and oil pan and look around. You can see just about everything with those removed.
Jim
Jim
#5086 12/22/2003 10:29 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I'd start by inspecting the valvetrain. You'll probably find something broken there. If not, then pull the oil pan, followed by the timing gear cover.
Fred 52 3600 69 C-10
#5087 12/22/2003 11:08 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If it was still running and the air cleaner muffled the sound, it is most likely a valve/valve train problem. Pulling the valve cover is the first thing to do. You may have a broken rocker or a dislodged pushrod.
They are a great motor to work on. I really enjoyed rebuilding mine and it now runs just as smooth as can be. I was offered a good running 235 but there is no way that I wanted to give up my 216. | | |
