2 members (elhippie64, baldeagle), 56 guests, and 12 robots.
Topics128,020
Posts1,055,345
Members48,420
#5084 12/22/2003 8:01 PM
Junior Member
Junior Member
I just bought a 46 Chevy truck with a 216 in it. The guy who had previously owned it said he was driving it and while driving it he heard a loud snap and then the engine started running ruff and would not idle. After the loud snap he said it made a thumping noise frown . He told me that when he would put the air breather on the carb it would muffle the sound. He has not ran the truck for over 5 years since that happend. I recently purchased the truck and I would like to fix the origanl motor were should I start.
#5085 12/22/2003 9:21 PM
Pull off the valve cover, pushrod cover, and oil pan and look around. You can see just about everything with those removed.
Jim
Jim
#5086 12/22/2003 10:29 PM
I'd start by inspecting the valvetrain. You'll probably find something broken there. If not, then pull the oil pan, followed by the timing gear cover.
Fred
52 3600
69 C-10
#5087 12/22/2003 11:08 PM
If it was still running and the air cleaner muffled the sound, it is most likely a valve/valve train problem. Pulling the valve cover is the first thing to do. You may have a broken rocker or a dislodged pushrod.
They are a great motor to work on. I really enjoyed rebuilding mine and it now runs just as smooth as can be. I was offered a good running 235 but there is no way that I wanted to give up my 216.
1951 1 Ton Completed
