| | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50833 10/04/2005 3:07 AM | Joined: Mar 2005 Posts: 49 Member | | Member Joined: Mar 2005 Posts: 49 | I was told by a hotrodder that when using a T-5, it has to be tipped slightly sideways to keep the OD from burning up. Were they installed on S-10's and camaros that way from the factory? I'm trying to decide on a T-5 or Saginaw for my '39 1/2 ton behind a 235. Any recommendations? | | |
#50834 10/04/2005 3:12 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Think he might be jerkin yer chain. It will only bolt up one way. You would have to tilt the engine to make that happen. Never heard of it. Lot of these guys have been running em for years. I've got 5000 miles on mine with no problems. | | |
#50835 10/04/2005 5:28 AM | Joined: Oct 2005 Posts: 2 Junior Member | | Junior Member Joined: Oct 2005 Posts: 2 | Theyre straight up and down in S-10's, but tilted toward the passenger side in camaros.
NEVER GONNA STOP!!
#50836 10/04/2005 2:46 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have a T-5 in mine, has been there only a few months but wish i had done years ago. i was wavering between that and a automatic. i was warned that it wouldn't work with a 2.73 nova rearend but works just fine. btw i live in flatland usa. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#50837 10/04/2005 3:05 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Ship's absolutely correct tilting the T5 tranny means tilting the engine. I'll let you know after mine goes into my 51 next week ... level.
so anybody got hens teeth, a left-handed monkey wrench or propwash ?
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#50838 10/04/2005 4:31 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 |
'67 GMC 3/4 292 4spd
#50839 10/04/2005 4:36 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Richard, This is a typical example of a mis-manufactured GM part...how dare they let this slip past the inspectors. Stuart. | | |
#50840 10/05/2005 1:14 AM | Joined: Mar 2005 Posts: 49 Member | | Member Joined: Mar 2005 Posts: 49 | Thanks everybody for the imput. I thought that sounded strange but you have to ask. I'll probably use an S-10 T-5 so my next challenge will be mounting my e brake handle and petals with the master cyl. Is this an easier mod that a saginaw? Being top loaded has got to be a plus. This is new to me; I've always run bone stock stovebolts but you can't hardly drive them in todays traffic. I'm thinking a rear in the 3.73 range would pull pretty good. I don't want to cruise more than 70 and I live in flat country (Florida). Any suggestions on the rear? | | |
#50841 10/05/2005 1:18 AM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Originally posted by Jonx4x4: Theyre straight up and down in S-10's, but tilted toward the passenger side in camaros. Correctamundo. | | |
#50842 10/05/2005 1:29 AM | Joined: Jul 2002 Posts: 20 Junior Member | | Junior Member Joined: Jul 2002 Posts: 20 | I'm a little late to get on board, but I have an S10 5 speed behind my 216 in a 40 pu. I plan on putting a 235 in later. I have a rear axle out of an S10 4wd auto. It is a 3.42 ratio. The 1st gear is a little low. I think I have the 4.03 first gear trans. Not a bad combo though.
Roy | | |
#50843 10/05/2005 1:34 AM | Joined: Mar 2005 Posts: 49 Member | | Member Joined: Mar 2005 Posts: 49 | Roy - I also have the same rear available to me. Did you stay with the 5 lug? What kind of cruise speed do you have? How about you're e brake set up? | | |
#50844 10/05/2005 1:46 AM | Joined: Jul 2002 Posts: 20 Junior Member | | Junior Member Joined: Jul 2002 Posts: 20 | I just mentioned the ebrake in another reply. I will get under and try to get a picture and description of the hook up. I haven't driven the truck much yet. It is still a project, but it has been driven on the highway. The speedometer is not hooked up yet, so I don't know the speed for sure, but it seems to keep up. I have a dropped tube axle up front. now has 54 chev drums. This give me 5 lugs all around. did have disc brakes on it and may go back to them after i change the single master cyl. I can't decide to stay with the dropped axle or go with a must2. I have a 50 pu with a must2 under it and it steers better than the straight axle. I kind of like to keep the old time look on the 40.
Roy | | |
