| | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | I bought some new radial tires and decided that I'm going to go tubeless. So where can I get the nipples for my 16" by 4" rims? In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The tire shop should have them. If not, then check with the flaps or nearest farm supply store.
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are called tubeless tire stems. They are available at any parts store. Ask for the large diameter type. They are available in different lengths if you are going to use full disc hubcaps. Other wise get the shortest ones. If your wheels are not in excellant condition they may not hold air. There has been discusions about useing radials on old rims but many have done it & have no problems. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | thanks. If it doesn't hold air I'll use tubes. I thought I'd try tubeless first. And they will be installed long before I can drive it. That will give it time to show if it is holding or not. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If they're tubless tires, you can't run tubes in them. They can cause tire failure and it is also against DOT regulations. Most (if not all) tire shops will not put tubes in tubeless tires.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | As with most aluminum rim's they alway's seem to leak,I ALWAY"S use a sealer on them,weather they look fine or not.I know your's are most likely steel but I'd use a sealer on them also.Now that I no longer work at a tire shop I alway's tell the person doing my tires to use a sealer,even on the valvestem.No more problem's with leaky rim's.One shop I was at I told em to use sealer and they said they did.Had 2 leaking overnight,Went back and had them fix em,they wanted to charge me for repair!!I say,you installed em yesterday,I requested a sealer thet you did not put on and by the way,you may as well reseal the other 2 tires while you are at it!!! | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | where can I get a sealer at? I'm putting them on myself. I thought there was such a thing as radial tubes? In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are radial tubes and I have had two different tire shops in NY put them on Toyo and Cooper LT radial tires. Not a question was asked nor a concern stated.
One set has been on for over 10 years; the other set only for 4 years.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Radial tubes are meant for tube type radial tires, not for use in tubeless tires. As I noted, it is illegal to put tubes in tubeless tires. I've personally seen what happens when that is done, especially with a tire that is run at highway speeds. Failure usually happens at about the 100 mile mark (about the distance from Indy to Danville). I wouldn't risk it.
