1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#507937 02/19/2009 11:41 PM
I bought some new radial tires and decided that I'm going to go tubeless. So where can I get the nipples for my 16" by 4" rims?
[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
davidn #507946 02/20/2009 12:00 AM
The tire shop should have them. If not, then check with the flaps or nearest farm supply store.
Bill Burmeister
davidn #507947 02/20/2009 12:01 AM
Riding in the Passing Lane
They are called tubeless tire stems. They are available at any parts store. Ask for the large diameter type. They are available in different lengths if you are going to use full disc hubcaps. Other wise get the shortest ones. If your wheels are not in excellant condition they may not hold air. There has been discusions about useing radials on old rims but many have done it & have no problems.
1972 Chevy c10 Cheyenne Super
LONGBOX55 #507948 02/20/2009 12:01 AM
thanks. If it doesn't hold air I'll use tubes. I thought I'd try tubeless first. And they will be installed long before I can drive it. That will give it time to show if it is holding or not.
davidn #507965 02/20/2009 12:43 AM
If they're tubless tires, you can't run tubes in them. They can cause tire failure and it is also against DOT regulations. Most (if not all) tire shops will not put tubes in tubeless tires.
Bill Burmeister
As with most aluminum rim's they alway's seem to leak,I ALWAY"S use a sealer on them,weather they look fine or not.I know your's are most likely steel but I'd use a sealer on them also.Now that I no longer work at a tire shop I alway's tell the person doing my tires to use a sealer,even on the valvestem.No more problem's with leaky rim's.One shop I was at I told em to use sealer and they said they did.Had 2 leaking overnight,Went back and had them fix em,they wanted to charge me for repair!!I say,you installed em yesterday,I requested a sealer thet you did not put on and by the way,you may as well reseal the other 2 tires while you are at it!!!
grub #508138 02/20/2009 8:02 AM
where can I get a sealer at? I'm putting them on myself. I thought there was such a thing as radial tubes?
davidn #508165 02/20/2009 2:25 PM
There are radial tubes and I have had two different tire shops in NY put them on Toyo and Cooper LT radial tires. Not a question was asked nor a concern stated.
One set has been on for over 10 years; the other set only for 4 years.
Radial tubes are meant for tube type radial tires, not for use in tubeless tires. As I noted, it is illegal to put tubes in tubeless tires. I've personally seen what happens when that is done, especially with a tire that is run at highway speeds. Failure usually happens at about the 100 mile mark (about the distance from Indy to Danville). I wouldn't risk it.
Bill Burmeister
