| | | Forums66 Topics128,032 Posts1,055,521 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 5 New Guy | | New Guy Joined: May 2008 Posts: 5 | on the dash of my 1950 to the left of the steering column is a little round pushbutton, about 1/2" in dia. doesn't seem to do anything when i push it. whats it for? looked through all the old online manuals i could find and not a one says anything about it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Maybe someone converted to a solenoid started and installed a push button in a hole they drilled into the dash? That location is where the solenoid-starter push button is located on Hydra-Matic-equipped 53-55 New Design and 54-55 Advance-Design trucks (and, maybe on Forward Control trucks/vans from 1948 and newer?).
Are there still wires connected to the rear of the push button?
| | | | | Joined: May 2008 Posts: 5 New Guy | | New Guy Joined: May 2008 Posts: 5 | no the starter is still on the floor and to be honest i haven't looked behind it to see if there are wires coming out or not. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | mem,
Welcome to the Stovebolt. Tim speaks the truth. I bought a '54 naked cab that had the small hole directly above the headlight switch hole, which is on the left side of the steering column.
I think Tim is actually the person that pointed out that this was the location for the starter push button for a Hydra-Matic rig. If your cab really did have this transmission, the transmission cover on the floor will be different too. Instead of being almost flat with the floor, the cover will extend up the toe-board for 4" or so.
There are probably more clues, but Tim would be the expert on those...my find was just a fluke.
Stuart
| | | | | Joined: Jun 2005 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 22 | When the 216 was replaced with a 235 in my 1950 Chevrolet they took out my stomp starter and replaced it with a solenoid starter and they put the button right between my headlight knob and gauge. And thats how I start my truck which in turn makes it a pain for me if my starter ever goes out because they totally eliminated my stomp starter stuff even the hole in the floor has sheetmetal welded there.
Josh S. 1950 Chevy 31001982 Jetta Diesel 1994 Chevrolet K1500 1996 Pontiac Grand Prix 2001 Chevrolet Suburban 2500 No honey, I don't NEED more toys I just need something fast enough to do something stupid in.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
