3 members (1955 1 Series, Rexville48, fonz8261), 64 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#506472 02/16/2009 1:45 PM
How hot can sheet metal get before you have to worry about warpage?
I am using a small propane torch and a scraper to remove the factory undercoating on the inside of my bed sides.
It works really well and I am making sure the metal doesn`t get too hot to touch on the front side.
Does anyone see any problems with this?
I have only done a small section and wanted to ask opinions before I go any further.
Thanks, Mike
Ex Hall Monitor
Ex Hall Monitor
I've not removed undercoating so I can't speak about the ease of removal but I have seen what too much heat can do to a panel. A propane torch is quite hot & can get too much heat into a panel quickly. It sounds like you're being careful. Just don't get in a hurry. How do you feel about trying a heat gun or high output hair dryer instead?
Well, I`m mainly just kind of going over the surface to soften it. Actually once the blade gets under it the stuff starts coming off pretty easily.
Like I said, I also am constantly feeling the other side with my bare hand to make sure it`s not getting too hot.
Mike
Don't worry about it.
Just think how hot a vehicle gets sitting in the direct sun in the desert... probably hot enough to burn your hand and make that undercoating drip off.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
