2 members (Bill Hanlon, 1 invisible),
131
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 59 | How hot can sheet metal get before you have to worry about warpage? I am using a small propane torch and a scraper to remove the factory undercoating on the inside of my bed sides. It works really well and I am making sure the metal doesn`t get too hot to touch on the front side. Does anyone see any problems with this? I have only done a small section and wanted to ask opinions before I go any further. Thanks, Mike | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've not removed undercoating so I can't speak about the ease of removal but I have seen what too much heat can do to a panel. A propane torch is quite hot & can get too much heat into a panel quickly. It sounds like you're being careful. Just don't get in a hurry. How do you feel about trying a heat gun or high output hair dryer instead?
| | | | | Joined: Nov 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 59 | Well, I`m mainly just kind of going over the surface to soften it. Actually once the blade gets under it the stuff starts coming off pretty easily. Like I said, I also am constantly feeling the other side with my bare hand to make sure it`s not getting too hot. Mike | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Don't worry about it.
Just think how hot a vehicle gets sitting in the direct sun in the desert... probably hot enough to burn your hand and make that undercoating drip off. | | |
