5 members (MickeyP, Gdads51, 55shaker, Paul_WNC, JW51), 153 guests, and 3 robots.
Topics128,093
Posts1,056,154
Members48,436
#506437 02/16/2009 5:46 AM
Hi fellow bolters,
After some time searching for a good '48-53 COE cab I have finally found one and will be picking it up this weekend. I have also found an '83 dually as a donor for Chassis and running gear so you can tell I am intending to mount the COE cab onto the later model Chassis. (apologies to the purists) What I am looking for is a Body tag of 7700lb gvw reason being to keep this truck LHD I need to be able to register it here with a gvw of 7700lb or less otherwise I will need to convert it to RHD and that just ain't right.
If anyone out there in stovebolt land can help out it would be greatly appreciated.
Willy
1959 Chevy Apache
1948 Chevrolet COE
Trucks are like womens handbags !! you can never have enough of them and they can carry all your worldly possesions
kiwiwilly #508916 02/22/2009 9:37 AM
Try these folks...
www.datatags.com
I found them in the current issue of Generator & Distributor
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Stick #509046 02/22/2009 7:29 PM
Big Bolt Forum Co-moderator
Wouldn't you need one for a 3/4 ton of that era? Wouldn't that raise a few eyebrows?
1948 Chevy 2-Ton
