2 members (55shaker, Peggy M),
78
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | I had the '37 out today running around in the sunshine, and the wife was noticing the exhaust smell. I have to admit, with the windows up it does smell a bit. Not rich fuel smell but just lots of normal exhaust stink! Would a universal CATALYTIC CONVERTER get rid of some of the smell, or would add to it? I have the idle jets set for 14.7 air to fuel ratio, so the lean condition is adding to the smell. A converter should also help it be "green" since thats in now. Joe | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I looked at your galary pictures (nice truck by the way) but I couldn't see where the exhaust exits. Aside from making sure there are no leaks underneath I would exit the pipes out the back or to the side behind the rear wheels. You don't want those nasty smells swirling around and coming back into the cab, expecially with mama in there. A cat would be about the last thing I'd put on my 'bolt but to each his own. My truck is already green anyway. | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | The pipe is under the rear fender and exits out the drivers side behind the rear tire. For one the doors don't seal 100% and two, its only when the wind is behind blowing the exhaust forward that you notice it. I don't mind cleaning up the exhaust emissions if I knew a converter would help. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the pipe was on when the pic on your page was taken, then it doesn't come out far enough to avoid being blown up under the fender, needs to dump outside the trucks air flow .... the problem prolly would go away if the pipe came out behind the truck instead of at the side - I doubt a catylic converter would make much difference in emissions, and wouldn't change the smell problem - certainly not enough to be worth wasting more of the planets limited supply of platinum [over $800/ounce!] on a system not designed to make proper use of it  Bill | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | This has been a problem from time to time that comes threw my shop. Some muffler shops will install a pipe and not know what the outcome will be.
You say it is behind the tire. That area does not get the air flow that it may need. I can not see it in the pictures. Does the pipe come out past the side of the bed?
If not then my best guess would be that the fumes are collecting under the bed area and being pushed back under the cab and into the inside.
Big question. Did this do this before you parked it for the winter?
The smell may be that the fuel has jelled up and it will take a good run with fresh gas to clear that up.
Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | It's always done it, I just lived with it. The pipe does need moved, I just haven't done it yet. I thought I might be able to help out the planet and solve the problem. I guess I need to read up on how the converters work, I never really thought much about them, plus order up some pipe.
Joe
| | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | ok, I will explain to you how they work. I would not recomend putting one on because it WILL reduce your Over all horse power.
What a Cad.converter does is. It will heat up and burn the unused fuel left over from the Comb. Chambers. They get real hot. and they to can smell if not used right.
For example. At the Cadillac Dealer I had a guy come in. The car runs off reg. gas.
On the first two rounds we replaced them under warrenty. Then We had some very clear questions for him. What gas is he using?
Turned out he used prem.gas... well for a short story. we would no longer replace the converter. so, If you want to use one you will need one to match the type of gas you are using.
His car smelled like a roten egg.
To fix your probem. You can just pick up a longer pipe to add to your tail pipe on the tip.
You can find those at most auto stores. It may take you an hour but, it will save you the problems. Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | catalytic converters are pretty technical items, either "2 way" or "3 way" reacting, and designed for the particular application, which nowadays includes way different fuel delivery and monitoring, including feedback from the converter - in their intended applications they can reduce some noxious emissions, but I doubt adding any ol one to your modified engine would do more than plug it up ... just keep'er well tuned
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Joe, are you sure the exhaust donut is not leaking and contributing making small problem even bigger?? Just a thought. | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I dump mine just ahead of the rear axle and have never had a problem with smell. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Could it be blow-by gases from the engine itself? | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | The whole system is tight, its just the normal old tail pipe smell. After driving new cars all the time, the old carbureted one just stinks more. And like I said, its only when the wind is behind blowing the exhaust forward and setting still. Once I get going, the exhaust is blown away and all is well. I run the engine very lean, so thats not helping anything. Joe
I do run with a 160 thermostat, so it may be to cold. I think I will bump it up to a 180 and see if it helps burn off some of the emissions.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A cat converter would not work on an old truck like that. It would get too hot & the rotten egg smell would be worse then the exhaust oder. It would brobably be short lived also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Somewhat related: The stovebolt sixes have they're own smell that is different from other engines I have had..My kitchen has a door that opens to the garage and some years ago I left it open while starting my truck and backing it out of the garage..the house stunk for almost a week..if it was a new car that smell would have been gone in 10 minutes..permeates clothes fabric..just nasty..I started a thread about it here: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=441543&fpart=1Keith | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Keith, That post is just what I'm talking about, just old exhaust! I push mine out of the garage some days before starting it just so the garage doesn't stink. Once I get home, I leave it out side till it cools, other wise the garage smells like fuel evaporating out of the intake. Joe | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You are more likely getting the smell from the crankcase fumes. You could convert your road draft tube to a PCV system. There was a PCV available for Cab Over and Box Van engine applications that kept the cab from stinking up in city use. The first emissions laws in the country required PCV, for a good reason. It really works, and doesn't rob any horsepower.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Personally I love the way my truck smells. I can close my eyes and be a kid again around that odor.
And as far as "saving the planet" I doubt that if you fired up every old vehicle in the world they wouldn't produce as much CO2 as one of those coal fired power plants they're building in China at the rate of one a week! | | |
