5 members (Hugh63c10, RoadsScholar, moparguy, SNOYL, Gray_Ghost), 100 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
When reassembling a Stovebolt tranny, do you guys use any kind of gasket seal, loc-tite, etc.? It's a 4 speed non-synchro type.
Neil
1940 GMC 1/2 Ton
The service manual does not say anything about gasket sealer, although it IS a manual from 1940. Let me know if anyone knows. Thanks.
Neil
1940 GMC 1/2 Ton
Don't always go by the service manual in these cases because most modern gasket and silicon sealants where NON existant back then.
My theory on old antique motorcycles stands w/ tractors too. Our bolts fit that class.
Yes to all, where needed as needed.
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
From hard experience I can tell you to also put a little non-hardening sealer on the cap screw threads that hold the front bearing retainer and shift plate.
I had to pull mine back out because trans oil would leak out around the threads.
Paul
When rebuilding your 4 spd, did you come across any nylon thrust washers? Just wondering about these nylon thrust washers I got in a rebuild kit for a 54 Muncie 3 spd and whether or not I can use steel (which a buddy who runs a tranny shop had).
Thanks for all the advice, guys.
Chevr aulait - my kit didn't have any thrust washers in it. The only thrust washer I found in the tranny is steel and in perfect shape. My kit did come with a couple of round cork gaskets. I've got one figured out.
Neil
1940 GMC 1/2 Ton
