3 members (carbking, GMCJammer51, 1 invisible),
224
Mod | | | Forums66 Topics128,284 Posts1,058,522 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50622 09/27/2005 6:38 PM | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | When reassembling a Stovebolt tranny, do you guys use any kind of gasket seal, loc-tite, etc.? It's a 4 speed non-synchro type.
Neil 1940 GMC 1/2 Ton
#50623 09/28/2005 5:28 AM | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | The service manual does not say anything about gasket sealer, although it IS a manual from 1940. Let me know if anyone knows. Thanks.
#50624 09/28/2005 6:22 AM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | Don't always go by the service manual in these cases because most modern gasket and silicon sealants where NON existant back then. My theory on old antique motorcycles stands w/ tractors too. Our bolts fit that class. Yes to all, where needed as needed.
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
#50625 09/28/2005 5:04 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | From hard experience I can tell you to also put a little non-hardening sealer on the cap screw threads that hold the front bearing retainer and shift plate.
I had to pull mine back out because trans oil would leak out around the threads.
Paul | | |
#50626 09/30/2005 6:03 AM | Joined: Sep 2003 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 50 | When rebuilding your 4 spd, did you come across any nylon thrust washers? Just wondering about these nylon thrust washers I got in a rebuild kit for a 54 Muncie 3 spd and whether or not I can use steel (which a buddy who runs a tranny shop had). | | |
#50627 09/30/2005 8:01 AM | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Thanks for all the advice, guys.
Chevr aulait - my kit didn't have any thrust washers in it. The only thrust washer I found in the tranny is steel and in perfect shape. My kit did come with a couple of round cork gaskets. I've got one figured out.
