0 members (),
37
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | You don't need an ignition module with a Unilite. You do need a coil. You can use a stock coil but I would go buy a high performance coil at any FLAPS. Read your installation instructions carefully because if I remember right you MUST use a ballast resistor with these. | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Thanks for the info. I thought I needed an ignition module.
Tom
48 Chevy 3100 Shortbox 5 window "The Big Dog"
