3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#506228 02/15/2009 7:18 PM
Closing in on the final phase of my project. Need to know what ignition module you would use. Using a Mallory Unilite distrib.
Have a 350 375 HP motor.
http://rides.webshots.com/photo/2377138890089166514fWahoy
http://rides.webshots.com/photo/2275346590089166514zEGNWp
What would you recommend?
Tom
48 Chevy 3100 Shortbox 5 window
"The Big Dog"
You don't need an ignition module with a Unilite. You do need a coil. You can use a stock coil but I would go buy a high performance coil at any FLAPS. Read your installation instructions carefully because if I remember right you MUST use a ballast resistor with these.
Thanks for the info. I thought I needed an ignition module.
Tom
"The Big Dog"
