Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Otto Skorzeny, UtahYork), 95 guests, and 5 robots.
Topics128,283
Posts1,058,505
Members48,490
#505920 02/14/2009 7:19 PM
Has anyone added a stiffener to there fender edges underside in the role?Is this advisable to prevent edge cracks?What is the best way to do this? Thanks
sooner,
On my 52 the passenger side front fender had cracked at the roll and collapsed leaving a nice crease right above the center of the wheel opening.
My body man popped it back out and Mig welded the crack then took a pc. of 1/4" round bar stock and formed it to fit the shape of the wheel opening lip and welded it in place on the back side to keep it from happening again.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Ex Hall Monitor
Ex Hall Monitor
As Tim pointed out, fixing the crack is easy. Keeping it from happening again is key. A brace of some kind to stop the work hardening & re-cracking of the metal is necessary. Time will tell whether the 1/4" bar stock used on Tim's ride is adequate. It seems a bit light to me but I hope I'm wrong.
