3 members (55shaker, JW51, Gdads51), 147 guests, and 1 robot.
Topics128,069
Posts1,055,896
Members48,428
#504481 02/11/2009 12:05 AM
I have a 1955 235 I bought and am putting in my 57. I got the oil filter housing with the motor. I went to NAPA yesterday & got a new oil filter for the 1955 235. I got it home and it is too small. The one in mine is 4 1/2 inches in diameter. The one from NAPA is 4 inches. My housing had the old filter in it.It is a WIX 51100 so today I went to a parts store that sells Wix & asked for the 51100 filter. They had one in stock & I took it out of the box and it is also 4 inches in diameter. Does anyone have a filter that is 4 1/2 inches in diameter? I don't know why if I have the filter number of my old one I can't get the same size. Any help is appreciated.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
in my 55 235, t have used the wix 51100 since i had the truck, it is 4 inch filter but i believe it is the correct filter
1955 CHEVY 3600 TF
wadd55 #504632 02/11/2009 4:42 AM
Everything I am coming up with says the filter I have is supposed to be 4 inch diameter, but it isn't. Maybe someone here has a 4 1/2 and can tell me where to get one??
I use a Fram C4P, the dia is 4 1/4".
Ed
Forty9 #504911 02/11/2009 10:13 PM
Riding in the Passing Lane
I looked it up in the Carquest catalog. First off Carquest, Napa, & Wix are all the same filters. The first diget in the part number designates the supplier. Carquest start with 8. The part # for the AC cartridge is 85100. It measures 4.531 O.D. & 5 in. height. The part # for the Fram is 85006. It measures 4.156 O/D. & 5.00 height. I'm thinking they have consolidated the 2 into one part #. The AC uses a top bolt with a 5/8 wrench size. The Fram has a bolt with 7/8 wrench & a few Frams have a big wing nut on top.
1972 Chevy c10 Cheyenne Super
The AC sounds like mine. It is the correct diameter & height & has a 5/8 bolt head on top. Now to show my ignorance, what does AC stand for & where would I get one? blush
Alan's 57 #505293 02/12/2009 10:25 PM
I don't know what AC originally stands for but it is a division of GM that makes filters & spark plugs, etc. All filter co's make replacements that should fit. Like I say they may have consolidated the AC & FRam into one part. If you can find a parts store that has the AC line they may have the original. I think the AC part number is c-21.
AC = Albert Champion
of the AC Spark Plug Company (1908) which became a GM division in 1933 (and by then it was making other things, including filters). AC Spark Plug Division
tclederman #505336 02/13/2009 12:21 AM
As long as the height of the filter element is correct, 1/2" of diameter won't make any difference. If the filter element seals properly at the top and bottom, the oil has to pass through the filter media, and a slightly shorter distance between the inner and outer folds of the element material won't affect how well, or how long it filters. Use either one!
Thanks guys.
Jerry, I called the WIX company & asked them if I have the old filter with the part number on it why I can't seem to get a replacement the same size. He could not tell me but said the same thing you told me. As long as the filter fits in the center it will not matter if it is 1/2 inch smaller in diameter. I will find out tomorrow night. I am going to try to fire her up for the first time. drive
According to the box
Hastings 207 replaces:
AC P115, P127
Fram C21, C21P
Purolator P51, P125
Wix 51100
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #505459 02/13/2009 4:50 AM
classicparts.com has 2 filters in their catalog. the od and the height are different. these trucks came with two different size oil filters canisters. I believe that you need to get the right od to get the right height
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
seetz #505712 02/14/2009 2:11 AM
Fram C4P(OR C4) is what I use. The cross over is:
WIX 51006
NAPA 1006
WALKER DELUXE WD36
PUROLATOR P34
-Tom
