1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#50463 09/23/2005 1:24 AM
Junior Member
Junior Member
Hi Fellow bolters. I just bought an 3 speed w/overdrive. And was hopeing to find a pageor imfo that shows now to wire this unit. Its going in my 50 1/2 with 3.73.in the rear. What was the first year Chevy offered O/D in a truck? And where would the O/D handle mount? Any pics out there ?. Thanks for any help.
Stock and loveing it.
#50464 09/23/2005 3:53 AM
The only experience with the old O.D. stuff was on my father-in-laws 55 Ford Customline. His service manual had a really well done schematic and description of how and why it's done the way it's done. The way it sounds from other posts, the Ford set-up is very simular if not the same. If you can't find decent Chevy info, look into this era Fords for the info you need. There's a governor (speed sensor), a solenoid and a fuse block that makes up the electrical and the push/pull handle that's just mounted under the dash. Did you get all of these pieces with your trans? Good luck, if need be maybe I can borrow the Ford manual from Pa in-law sometime for you,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#50465 09/23/2005 10:14 AM
Go down to the topic titled "How does the overdrive in my '55 second series work". All sorts of good info there.
Andy
#50466 09/25/2005 12:04 PM
Here you will find the original setup:
Overdive
Overdive 2
Overdive 3
and here is some specific inormation on the electrical stuff
OD Electrical
hope that helps.
If you need aditional help drop me a line, I got the original OD Shop manual and can scan some pages of intrest if you need em.
Frank
#50467 09/25/2005 11:39 PM
Z
Z Offline
ive been "forbidden".
#50468 09/28/2005 2:42 AM
Y
Y Offline
All of the original manuals have been posted in .pdf format at www.speedprint.com/Deves50/overdriveindex.php
