6 members (Charles in CA, 55shaker, elhippie64, TUTS 59, Gdads51, 3800GUY), 86 guests, and 1 robot.
Topics128,118
Posts1,056,302
Members48,439
#504444 02/10/2009 10:54 PM
What needs to be changed to use open drive shaft on this rear axle and get rid of the torque tube? running a 235 with a turbo 350 Thanks
Welcome to the shop! If it were mine, I'd get a 69-70 1/2 ton rear end with a 3:08 gear in it. Pretty cheap, almost a bolt-in, and will let you cruise in the hammer lane. Get the driveshaft too, you might get lucky and it'll fit with no mods.
The earlier years, 55/56 will also work but the 3.90 is pretty low. These and the years mentioned above will still let you use the same axles with 6 lugs.
