2 members (Otto Skorzeny, dt235sd), 122 guests, and 1 robot.
Topics128,052
Posts1,055,719
Finally got around to installing a fuel filter on Lurch, the '51 Chevy. There was a thread a while back about the best place to put it, I finally opted to cut into the fuel line just ahead of the carb. Job went pretty smooth, but make sure you have a good tube flaring tool available before you start. My flaring tool was a POS, & I ended up running over to NAPA for a good one.
[img]http://webpages.charter.net/fredstev/fuelfilter.jpg[/img]
Looks great! Thats a good location I need to do the same thing.
Steve
great pic.. that big guy should work just fine, I have one in the same place but one of those smaller ones,,, thanks for showing.Fred
Redryder pix
My Hotrod
Seems to be a nice example of an original paint/color engine for those of you who have this question.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Riding in the Passing Lane
Thats nice & sanitary. You can put it right up to the carb with a 1/8 pipe nipple.
1972 Chevy c10 Cheyenne Super
Quote
I really considered doing that but didn't for two reasons. It would have made it difficult to remove the top of the Rochester carb for cleaning and servicing. Installation would have been awkward because I would have had to spin the filter body on to the pipe nipple and there is nowhere to put a wrench to tighten it.
Also, I don't think that thread is 1/8" pipe or 1/4" pipe thread. A 1/4" nipple threaded in, but fit loosely. As I recall, my thread gauge said that the original fitting was 16 tpi.
Another hint if you want to use this type of filter. Order an extra filter and bowl gasket when you buy the filter.
The really big reason is because the gas swells up the bowl gasket considerably. If you have to do a roadside filter cleaning or replacement, you will have a fresh gasket to use. The old, swollen one will shrink back to normal in a few hours, so save it.
that's how mine is on my 49 (doing a frame up now) i'm going to change it back to the original setup- 1. to make it factory appearing, and 2. for safety..... they way you have it is right above the exhaust manifold.... if it would leak or have the glass bowl broke.... poof
Bondo Artiste
Bondo Artiste
Fred, nice job.
I think that filter is a nice touch to your truck.
~ Phillip
