0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50413 09/22/2005 2:56 PM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Finally got around to installing a fuel filter on Lurch, the '51 Chevy. There was a thread a while back about the best place to put it, I finally opted to cut into the fuel line just ahead of the carb. Job went pretty smooth, but make sure you have a good tube flaring tool available before you start. My flaring tool was a POS, & I ended up running over to NAPA for a good one. [img] http://webpages.charter.net/fredstev/fuelfilter.jpg[/img] | | |
#50414 09/22/2005 3:49 PM | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | Looks great! Thats a good location I need to do the same thing. Steve | | |
#50415 09/22/2005 4:15 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | great pic.. that big guy should work just fine, I have one in the same place but one of those smaller ones,,, thanks for showing.Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#50416 09/22/2005 4:20 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Seems to be a nice example of an original paint/color engine for those of you who have this question. | | |
#50417 09/22/2005 9:43 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Thats nice & sanitary. You can put it right up to the carb with a 1/8 pipe nipple. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#50418 09/22/2005 9:59 PM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Originally posted by Wrenchbender Ret.: Thats nice & sanitary. You can put it right up to the carb with a 1/8 pipe nipple. I really considered doing that but didn't for two reasons. It would have made it difficult to remove the top of the Rochester carb for cleaning and servicing. Installation would have been awkward because I would have had to spin the filter body on to the pipe nipple and there is nowhere to put a wrench to tighten it. Also, I don't think that thread is 1/8" pipe or 1/4" pipe thread. A 1/4" nipple threaded in, but fit loosely. As I recall, my thread gauge said that the original fitting was 16 tpi. | | |
#50419 09/23/2005 12:38 AM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Another hint if you want to use this type of filter. Order an extra filter and bowl gasket when you buy the filter.
The really big reason is because the gas swells up the bowl gasket considerably. If you have to do a roadside filter cleaning or replacement, you will have a fresh gasket to use. The old, swollen one will shrink back to normal in a few hours, so save it. | | |
#50420 09/26/2005 12:49 AM | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | that's how mine is on my 49 (doing a frame up now) i'm going to change it back to the original setup- 1. to make it factory appearing, and 2. for safety..... they way you have it is right above the exhaust manifold.... if it would leak or have the glass bowl broke.... poof | | |
#50421 09/26/2005 12:55 AM | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Fred, nice job.
I think that filter is a nice touch to your truck.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | |
