1 members (Gray_Ghost),
104
Mod | | | Forums66 Topics128,164 Posts1,056,967 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50368 09/20/2005 6:37 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | "Carbking" reply to a recent post suggested I put a Carter 400 CFM carb. on my Offy intake for my 250c.i. Either a model 9400 or 9410. Only problem is... I can't find a new one anywhere. Is there a place where these exist that I haven't found or is there another one which is it's equal by another name/number/manufacture? Thanks. Your comments please.
#50369 09/20/2005 9:03 PM | Joined: Feb 2004 Posts: 29,860 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,860 | The Holley #7448 350 CFM 2-barrel is a good choice for engines the size of the 250. They're available through JEGS, and various other internet/mail order suppliers. We use them on the NASCAR round track engines instead of restrictor plates, on the low-budget "claimer" engines. A properly set-up Chevy 350 will run 6,200 RPM with one of these carbs, so a 250 I-6 definitely won't be under-carbureted with one installed! Holley also makes some low-volume 4-barrels if you've just gotta have four holes to breathe through, but a 4-BBL on an I-6 is a waste of time and money, IMHO! Jerry
#50370 09/20/2005 10:15 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Yep, HRL is right again but darn those 4bbls look so cool! | | |
#50371 09/20/2005 10:24 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | oldchevytrucks.com supplies a 390 CFM Holley.
Mike Barnes 1950 GMC 1-ton pickup
#50372 09/20/2005 10:53 PM | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Carter discontinued the 9410 (which superceded the 9400) in the late 1970's due to lack of interest (many wanted to put two 750's on a 283 - bigger is better). Finding a new carb might be difficult. I simply suggested that this carb would be the easiest to tune, as it was calibrated from the factory for the 283. Used/rebuilt carbs are available, but you have to look.
Also, I would certainly agree with Hotrod Lincoln on the 2 barrel (although I would personally pick a Rochester instead of the Holley). We have had a number of customers get 6800 on a 383 Chevy on 3/8 mile dirt track with a rejetted 400 Chevrolet 2-barrel.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#50373 09/21/2005 12:21 AM | Joined: Feb 2004 Posts: 29,860 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,860 | Yep, I'd pick a Rochester, too, if I could! The local track specifies not only the brand of carburetor, but the part number, too! BTW, I just edited the former post for the correct part number. It's a #7448! There's also a 500 CFM 2-BBL Holley that will breathe a little better, but our myopic tech crew won't pass that one! Jerry
#50374 09/21/2005 1:23 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I wrote a tech artice on various carbs I tried out on my Chevy 261 engine for Inliners Newsletter.The engine was in a good state of tune,3/4 cam,Fenton headers,more compression,proper valve job,minimal cylinder leakdown.A 250 Chevy breathes better than the 261,but the comparisons should hold true for both engines. All carbs were on a Clifford water heated intake,Carter(expensive) 400 cfm,Holley 390 4bbl,Holley 350 and 500 cfm 2 bbls,500 cfm Edelbrock.The carbs were jetted if necessary for best cruise vacuum and wide open throttle performance.Part throttle response was judged by by "feeling",wide open throttle performance was timed on a back road, between 2 power poles using 2000-4500 rpm in second gear. In the end,they all performed pretty much the same,but the Holley 390 4bbl offered better midrange respnse due to it's easily adjustable vacuum secondaries.It was the only 4 bbl that you could quickly floor the accelerator pedal at 1000 rpm in first gear,and it would pull to readline with seamless power.No real difference in fuel mileage between carbs for my tests.The Holley 350 and 500 2bbls(about 270 and 370 cfm respectively if you rate them as 4bbls),ran well,but the 500 2bbl may be slightly large for slow speed work depending on your engine tune. A few guys on this site run Holley 390 and 450 4bbls I rebuilt for them on 292 Chevy engines,they seemed to be satisified,like I didn't get any death threats. 60's Ford V-8's and 266 and 304 IHC truck engines use a Holly 2 bbl that's more or less similar to to a new Holley 350 2bbl.You can pick them up on the cheap from Ebay.A good deal if you're capable of rebuilding a carb.The stock jets in these carbs work out ok on a Chevy 6. I also tried out a large Rochester 2 bbl 2GC,I was not satisifed with the performance,and time ran out before I jetted it properly. I hear some guys say Holleys always leak fuel,they do if you're ham fisted,it's nice they don't have fidgety little springs and metering rods that always fall into crevices when doing jetting changes with carb on engine.  | | |
#50375 09/21/2005 2:45 AM | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | I followed the info Tony previously provided and am running a 390 Holley on my 261. If you look at my engine pic you'll probably notice that it's mounted backwards--that's so I could use my old "footfeed" and fabricate a linkage and cable system that doesn't stick out like a sore thumb. Running 50's and a little heavier spring. Life is good.  | | | | | Joined: Dec 2008 Posts: 16 Apprentice | | Apprentice Joined: Dec 2008 Posts: 16 | Hi, I am needing a decent, straight 63 grille. Painted or chrome. Maybe a pair of headlight trim rings also. Let me know what you have. Thanks Tim
Be happy with what you have. Not unhappy with what you have'nt.
| | | | | Joined: Dec 2008 Posts: 16 Apprentice | | Apprentice Joined: Dec 2008 Posts: 16 | Hey all, Still looking for that 63 grille. Please let me know if you run across one.
Thanks Tim
| | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | I have 2 Chevy '60-'66 stepside short beds (just the bed) for sale. good condition. $400 each. If anyone is interested, e-mail me @ [email protected] and i will send u a photo of the beds. Benjo | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | I have a 74-78 chevy front end for sale. good condition. $200. will separate into front clip or fenders. $75 for each fender. Anyone interested? E-mail me at [email protected] and i will send you a pic of the front end. Benjo | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | I have '68 gmc , and '69 chevy fenders for sale. good condition. $125 each. Interested? e-mail me at [email protected]. | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | I've got a 69-71 chevy hood (not for grill lip molding) and also i have a 63-66 chevy hood for sale . good condition. $175 each. Interested? e-mail me at [email protected] and i'll send you a pic of the hoods. | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | I've got a '68 GMC hood ( For grill lip molding)for sale. good condition. $125. E-mail me if interested at [email protected] | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | The following parts for sale are for 60-66 Chevy trucksand are all rust free.Side cowels, - $80 pair, $40 each (5) windsheild cowels - $30 each (5) 63-66 Chevy hoods - $175 each 60-62 chevy hood - $200 (2) pair 60-62 chevy doors. $300 each pair '69 chevy centergrill - $75 (3) pairs of 60-66 chevy inner fenders., - $45 each (3) front radiator supports - $85 each. I've got tons more parts. if you e-mail at [email protected] me and let me know what you're looking for. I probably have it for any classic chevy. benjo
Last edited by GMONIZ; 02/17/2009 8:55 PM. Reason: DIRECT ALL INQUIRIES TO e-mail at [email protected] or PM the seller.
| | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | I've got 2 60-62 chevy truck cabs in fairly good condition for sale. And one in better condition than the other. $650 for the nicer one. $600 for the other two. Interested? E-mail me at [email protected] and i will send you a picture of the cabs. benjo | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | I've got a 60-72 3 speed saganaw transmissionw/ v8 bell housing for sal. $200. I'm in nevada. interested, e-mail me at [email protected]. | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | i've got '58 chevy truck doors for sale. $200 each. rust free. e-mail me at [email protected] if interested. benjo | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | I've got 3 60-66 chevy front aprons for sale. $110 each. e-mail me at [email protected] if interested. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | What are you calling front aprons?
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: Feb 2009 Posts: 5 New Guy | | New Guy Joined: Feb 2009 Posts: 5 | do you still have the doors for the 62 chevy and are they complete with working windows. please email pics if possible my email is [email protected] thanks | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | i do still have the doors, complete with working windows, hinges,and window cranks. it's sitting at a friend's house and i won't be able to get a picture for a few days. | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | i've got headlight bezels for a 63 pickup.$25 | | | | | Joined: Dec 2008 Posts: 16 Apprentice | | Apprentice Joined: Dec 2008 Posts: 16 | Sent you an email. Thanks
| | | | | Joined: Dec 2008 Posts: 16 Apprentice | | Apprentice Joined: Dec 2008 Posts: 16 | Hey Benjo, Thanks, but I already found a pair. Also, there is a grille on it's way to me. UPS Tracking says "Out For Delivery" today. Fingers crossed. Tim
| | | | | Joined: Feb 2009 Posts: 5 New Guy | | New Guy Joined: Feb 2009 Posts: 5 | | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Looking for a dimpled rear fender for a 64' Stepside longbed. Any on hand? Thanks DJ "Tramp" Durant | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | dimpled? what do you mean? | | | | | Joined: Jan 2009 Posts: 14 New Guy | | New Guy Joined: Jan 2009 Posts: 14 | | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Benjo, check your PM mail.
| | | | | Joined: Dec 2008 Posts: 16 Apprentice | | Apprentice Joined: Dec 2008 Posts: 16 | Not at this time, but will keep you in mind. May here of someone else looking. Thanks
