2 members (Samantha, carbking),
112
Mod | | | Forums66 Topics128,278 Posts1,058,573 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Alright I've checked, rechecked, inspection mirrored, basicly everything I can think of and I can not find this dog gone leak. It's on a '78 SBC 350 and I keep getting oil drops off the nose and bolts of the starter. It's not the valve covers, not the back of the intake, not the rear main, not the sender I just can't find it and it drips right on my exhaust. Before I drop the starter, is there an oil port plug behind the starter I can't see?? I can't stand this anymore and it's driving me crazy.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Look at the distributor, The gasket on my van was leaking and running down the right side. I changed gaskets on the dizzy and leak was gone. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Also, there is a plug at the top of the block, behind the intake(partially covered by the intake) that I have seen leaking and running down the back of the engine. You can see it with a good mirror.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 47 | Possible oil sending unit behind intake,cam plug between engine and transmission,or distributor gasket. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I have seen the following missed and a small oil leak results. In front of the fuel pump on the front block face there is a bolt hole for holding the fuel pump rod when replacing the pump. It normally holds a short bolt to keep oil from leaking out the hole. When you remove the fuel pump you use one of its longer bolts by removing the short bolt and screwing in the long one. When the long bolt is removed and reinstalled in the fuel pump the short bolt is sometimes forgotten.
| | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Thanks for the info guys but really I've already checked all of them several times over. Beltfed I did the fuel pump bolt missing early in the build, replaced it and have even helped out a friend with the same thing. The biggest thing I can not understand or find is why the oil is only comming off the nose of and the mounting bolts for the starter. Everything else is dry and clean. The first two things I thought of were the valve covers and the back of the intake, nothing but dry. The sender and the distributor the same thing, dry. Above the starter up to the plugs and valve cover, dry. The flywheel and inside the bell housing, dry. I took the inspection cover off to make sure and have left it off. I just have no ideas left where this dog gone leak is comming from.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If that's the only leak your small block has, consider yourself lucky, LOL. Anyway, maybe you have a starter mounting bolt hole that has a crack going into an oil passage. I would remove the bolt that has the drop and clean it and the hole with brake cleaner and install it with some sort of sealer. Maybe there's some oil residue inside the starter from a previous oil leak. Got some pictures that we can see? Scott | | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | Bluepen: ever thought about doing a u/v dye test ? We use a ultraviolet dye added to the oil to find leaks. Clean everything up good, add the dye, drive it about 200 mi & shine a u/v light around under the engine. That will point out the source of the leak. Good luck
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
| | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Nvr thats something I would have never thought of. I do have one question on it for you , I've never seen the UV dye for oil only for AC units. Would you happen to know the brand name or someplace I might get from? I spent the other day on my back rechecking everything and cleaning again but ran out of time before I could run it to see if I could find anything. I was going to do that this weekend, it does not take very long for it to start driping so I'll try again and see what happens.
| | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | We get our dye from Napa or Car Quest. There is one for oil & one for a/c. They both do the same job.
