7 members (3B, msmall, Bill Hanlon, FrankenChevy, walter74, Stovebolt48, Shardean),
60
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | i am installing a 350 inplace of my 235. Can i use the exsisting sterring column and sterring box. does it have to be moved | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You can use the steering column by modifying it to use a different box. Otherwise you can use the stock column and box but need to shift them outward to squeese a V-8 in there.
Do a little searching, lots of guys have dealt with this challenge.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 53flatbed: as OldSub has said do a little searching. If you do not use the search feature I would even suggest just going through the driveline post for the past few days or so. It won't take long and there is tons on this subject. I've posted many myself along with what others are doing. Just to get you started you can use the original by moving it over, some use a 4/4 toyota box with power steering, some use a GM....these will mount on the side of the chassis towards the front and usually require an ajustable drag link, and maybe even a different pitman arm. As I have read it is not that hard to do. Some use a column out of a 80's GM van for the tilt wheel and the switch is still located in the dash and not the column.
So far, I'm "planning" on using the original box, moved out about 1 1/2" and using a 68 column since I want to have turn signals on the column and it and the switch will still be in the dash. Lots of choices and I want make the final decision until I get there...which I am just about there now! Good luck, keep us posted and happy hunting. | | |
