3 members (1955 1 Series, Gdads51, 1 invisible), 75 guests, and 2 robots.
Topics128,037
Posts1,055,582
#502652 02/06/2009 8:29 PM
Apprentice
Apprentice
I need some advice on which way to go with the rods on my 51 216 I am rebuilding. It's the last thing I need and the crank is at the machine shop getting the rod journals turned. (down to what I don't know yet). Cost is the main issue but if I could get it done similar in cost I would go with getting my rods machined to take inserts. I can't find anyone in Northern WI that will machine them for me. Any body know a place to send them? Jim Carter is about $48 each for babbitt or machined, plus $113 for bearings for the machined. What do you all think?
Tuley #502714 02/06/2009 11:28 PM
I had my rods machined and I bought my inserts on ebay. You end up with a modern bearing material that should give better service.
1951 1 Ton Completed
Apprentice
Apprentice
truckernix, where did you have the rods machined, and what did it cost? I haven't found anybody around here yet that will do it.
Tuley #502734 02/07/2009 12:37 AM
Talk to EGGE. www.egge.com
Drew
DrewP #502921 02/07/2009 12:32 PM
I am in Ontario Canada and I think I paid about $75 a rod to a local machine shop. I think Egge might be able to help you. The February issue Custom Classic Trucks has a good article on Egge. One of the photos shows a really ancient rod that has been redone.
Apprentice
Apprentice
Do you think Egge will be cheaper than Jim Carter?
Tuley #503323 02/08/2009 2:07 PM
Never used these guys, but I believe they do the rods for Carter's.
http://www.parkville.info/pauls/index.htm
Surprised you can't find a shop to do it. Pretty simple procedure, hone the big end to size and notch it for the bearing tang.
Bob
Apprentice
Apprentice
Thanks Bob I will check with them.
Tuley #503342 02/08/2009 3:38 PM
I finally found my EGGE Invoice from June of 08. 216 Rods were $34.00 each/ Total $204 and new bearings for same $127.50.UPS to NJ $22.13.
Drew
DrewP #503355 02/08/2009 4:26 PM
Apprentice
Apprentice
Drew, are the bearings Federal-Mogul bearing part number 1415SB? Thanks for the prices, I have so much in this 216 and rods are the last thing I need,I hope.
Tuley #503441 02/08/2009 8:25 PM
Well, the box is non-descript,but does have this number:
6 11415HD STD and EGGE # CB503.000. The STD refers to stock crank measurement for the rods.
Drew
DrewP #503447 02/08/2009 8:31 PM
The machining operation is a boring operation. First thing they do is remove the babbitt. Next the rod parting surfaces are cleaned up and then they ae bored. The last thing is to notch them for the bearings. It all has to be done in a very precise manner.
