| | | Forums66 Topics128,272 Posts1,058,316 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 29 Apprentice | | Apprentice Joined: Mar 2008 Posts: 29 | I need some advice on which way to go with the rods on my 51 216 I am rebuilding. It's the last thing I need and the crank is at the machine shop getting the rod journals turned. (down to what I don't know yet). Cost is the main issue but if I could get it done similar in cost I would go with getting my rods machined to take inserts. I can't find anyone in Northern WI that will machine them for me. Any body know a place to send them? Jim Carter is about $48 each for babbitt or machined, plus $113 for bearings for the machined. What do you all think? | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I had my rods machined and I bought my inserts on ebay. You end up with a modern bearing material that should give better service. | | | | | Joined: Mar 2008 Posts: 29 Apprentice | | Apprentice Joined: Mar 2008 Posts: 29 | truckernix, where did you have the rods machined, and what did it cost? I haven't found anybody around here yet that will do it. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Talk to EGGE. www.egge.com
Drew
| | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I am in Ontario Canada and I think I paid about $75 a rod to a local machine shop. I think Egge might be able to help you. The February issue Custom Classic Trucks has a good article on Egge. One of the photos shows a really ancient rod that has been redone. | | | | | Joined: Mar 2008 Posts: 29 Apprentice | | Apprentice Joined: Mar 2008 Posts: 29 | Do you think Egge will be cheaper than Jim Carter? | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Never used these guys, but I believe they do the rods for Carter's. http://www.parkville.info/pauls/index.htmSurprised you can't find a shop to do it. Pretty simple procedure, hone the big end to size and notch it for the bearing tang. Bob | | | | | Joined: Mar 2008 Posts: 29 Apprentice | | Apprentice Joined: Mar 2008 Posts: 29 | Thanks Bob I will check with them. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I finally found my EGGE Invoice from June of 08. 216 Rods were $34.00 each/ Total $204 and new bearings for same $127.50.UPS to NJ $22.13.
Drew
| | | | | Joined: Mar 2008 Posts: 29 Apprentice | | Apprentice Joined: Mar 2008 Posts: 29 | Drew, are the bearings Federal-Mogul bearing part number 1415SB? Thanks for the prices, I have so much in this 216 and rods are the last thing I need,I hope. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Well, the box is non-descript,but does have this number: 6 11415HD STD and EGGE # CB503.000. The STD refers to stock crank measurement for the rods.
Drew
| | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | The machining operation is a boring operation. First thing they do is remove the babbitt. Next the rod parting surfaces are cleaned up and then they ae bored. The last thing is to notch them for the bearings. It all has to be done in a very precise manner. | | |
