| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50315 09/19/2005 6:25 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | new problem, same truck. i'm replacing the carb spacer but i can't find a way to reuse the metal collar with 2 'ears' on it that was inside my old spacer which i'm replacing. do i need this metal liner or can i just push the spacer down onto the gasket on top of the intake manifold and then put the top gasket on and then the carb? (manifold, gasket, spacer, gasket, carb, no metal liner). i hope this isn't too confusing. thanks
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#50316 09/19/2005 1:27 PM | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | I don't have a gasket under my spacer.
I have manifold, spacer, gasket, carb.
Bill Schickling | | |
#50317 09/20/2005 1:54 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | thanks bill for the reply.
#50318 09/20/2005 3:01 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If your spacer is metal, it needs a gasket. If it's plastic, you usually don't have to have one. Your local auto parts store should have one if you need it.
Fred 52 3600 69 C-10
#50319 09/20/2005 3:17 AM | Joined: Mar 2005 Posts: 49 Member | | Member Joined: Mar 2005 Posts: 49 | I made a wood spacer for my carb. No gaskets. The main purpose is to keep heat transfer out of the carb. A number of materials will work. | | |
#50320 09/20/2005 3:25 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Iv'e seen alot of wood spacers on all kinds of cars at cruises lately. I just got Jim Carter's new catalog and he's got a diagram in the back that shows carb, gasket, spacer, gasket and manifold. Both gaskets have the same #. | | |
#50321 09/20/2005 6:10 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | i'm glad to hear it shipwright because i left the gasket on the manifold and just put the plastic spacer and another gasket on top. i haven't fired her up yet, so i'll advise when i do. thanks to all for your help tony
#50322 09/20/2005 10:21 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I have a 53 Hudson manual that specifies 7 gaskets are to be installed under the carb. No spacer.
Mike Barnes 1950 GMC 1-ton pickup
