1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#50315 09/19/2005 6:25 AM
new problem, same truck. i'm replacing the carb spacer but i can't find a way to reuse the metal collar with 2 'ears' on it that was inside my old spacer which i'm replacing.
do i need this metal liner or can i just push the spacer down onto the gasket on top of the intake manifold and then put the top gasket on and then the carb? (manifold, gasket, spacer, gasket, carb, no metal liner).
i hope this isn't too confusing. thanks
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#50316 09/19/2005 1:27 PM
I don't have a gasket under my spacer.
I have manifold, spacer, gasket, carb.
Bill Schickling
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#50317 09/20/2005 1:54 AM
thanks bill for the reply.
#50318 09/20/2005 3:01 AM
If your spacer is metal, it needs a gasket. If it's plastic, you usually don't have to have one. Your local auto parts store should have one if you need it.
Fred
52 3600
69 C-10
#50319 09/20/2005 3:17 AM
I made a wood spacer for my carb. No gaskets. The main purpose is to keep heat transfer out of the carb. A number of materials will work.
#50320 09/20/2005 3:25 AM
Iv'e seen alot of wood spacers on all kinds of cars at cruises lately. I just got Jim Carter's new catalog and he's got a diagram in the back that shows carb, gasket, spacer, gasket and manifold. Both gaskets have the same #.
#50321 09/20/2005 6:10 AM
i'm glad to hear it shipwright because i left the gasket on the manifold and just put the plastic spacer and another gasket on top. i haven't fired her up yet, so i'll advise when i do. thanks to all for your help
tony
#50322 09/20/2005 10:21 PM
I have a 53 Hudson manual that specifies 7 gaskets are to be installed under the carb. No spacer.
Mike Barnes
1950 GMC 1-ton pickup
