4 members (Tim Canfield, Bill Hanlon, Hotrod Lincoln, 55shaker), 108 guests, and 4 robots.
Topics128,195
Posts1,057,380
Members48,469
I'm building a 57 1/2 ton Panel, 350(carburetored), air conditioned. First,I need the dimensions of the original stock radiator. There wasn't a radiator in the truck when I got it. Is there a universal aluminum radiator out there that will work on this model without much fab work? Thanks in advance for your help.
your best bet would to be to find a stock rad, it'll work fine, although with a V8 you'll need a shroud [unless it was originally a V8] because the fan will be way too far back
Ditto what red says. Or if you have a concern or can't find a good one, get one with good tanks and have it recored with a larger core. That will be much cheaper that an aftermarket and will fit the first time.
Bill Burmeister
If you still need the dimensions for the stock radiator I can get you them when I get home in about an hour, and if you are looking for a stock radiator with good tanks to have recored I have one that I'd be willing to sell cheap.
Neil
1955 Chevy 3200
The stock standard radiator is 25 1/2 tall, 21 1/2 wide (not including mounting brackets), and 3 inches deep (not including the pipes in/out of the radiator, which adds an additional 1 to 1 1/4 inches).
Neil
1955 Chevy 3200
I replaced the radiator in my '58 and have the old one if you're interested. It will need a bit of a rebuild. I'm not sure if it will work in a '57 though.
I see you already have the measurements. On my 55 I am still using the stock radiator with a built 350. The truck was originally a 6 cyl truck. The only thing I added was a good shroud. My 350 now runs about 170 degrees.
I used the original rad in my 58 with a very stout 350. I had the rad rebuilt and am using an electric fan attached to it with a thermal control. It never runs hot.
'58 Apache Short Fleetside on a '64 chassis
This is an AFCO 26X20 I put in my '57 (Summit part# AFC-80103NP). The fan is a flex-a-lite 180 (3300 CFM). I needed to make a couple of backets to adapt the rad to the core support, but it was an easy fab. This rad doesn't have an auto trans cooler.
http://picasaweb.google.com/ChrisAurit/ItSChrisGreenTruck#5242121123234200946
