| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 7 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 7 | I'm building a 57 1/2 ton Panel, 350(carburetored), air conditioned. First,I need the dimensions of the original stock radiator. There wasn't a radiator in the truck when I got it. Is there a universal aluminum radiator out there that will work on this model without much fab work? Thanks in advance for your help. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | your best bet would to be to find a stock rad, it'll work fine, although with a V8 you'll need a shroud [unless it was originally a V8] because the fan will be way too far back
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Ditto what red says. Or if you have a concern or can't find a good one, get one with good tanks and have it recored with a larger core. That will be much cheaper that an aftermarket and will fit the first time.
Bill Burmeister | | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | If you still need the dimensions for the stock radiator I can get you them when I get home in about an hour, and if you are looking for a stock radiator with good tanks to have recored I have one that I'd be willing to sell cheap.
Neil 1955 Chevy 3200
| | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | The stock standard radiator is 25 1/2 tall, 21 1/2 wide (not including mounting brackets), and 3 inches deep (not including the pipes in/out of the radiator, which adds an additional 1 to 1 1/4 inches).
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I replaced the radiator in my '58 and have the old one if you're interested. It will need a bit of a rebuild. I'm not sure if it will work in a '57 though.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I see you already have the measurements. On my 55 I am still using the stock radiator with a built 350. The truck was originally a 6 cyl truck. The only thing I added was a good shroud. My 350 now runs about 170 degrees. | | | | | Joined: Feb 2005 Posts: 8 New Guy | | New Guy Joined: Feb 2005 Posts: 8 | I used the original rad in my 58 with a very stout 350. I had the rad rebuilt and am using an electric fan attached to it with a thermal control. It never runs hot. | | | | | Joined: Jan 2009 Posts: 2 New Guy | | New Guy Joined: Jan 2009 Posts: 2 | This is an AFCO 26X20 I put in my '57 (Summit part# AFC-80103NP). The fan is a flex-a-lite 180 (3300 CFM). I needed to make a couple of backets to adapt the rad to the core support, but it was an easy fab. This rad doesn't have an auto trans cooler. http://picasaweb.google.com/ChrisAurit/ItSChrisGreenTruck#5242121123234200946 | | |
