3 members (mick53, 1955 1 Series, Maybellene), 77 guests, and 1 robot.
Topics128,157
Posts1,056,872
Members48,456
One of my leaf springs keep coming off the mount in the rear. Can this be fixed? Where can I get replacements for them if i can't fix them?
1949 Chevy 4400 Grainbed
Photobucket pictures
The taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back!
Behind every successful rancher is a wife who works in town.
49' Hayhauler, could you post a picture of the spring as it is when it's off... a diagnosis will be a lot easier.
Paul.
1948 Chevy 6400
1964 Chevy 1/2 Ton
Yes, 49'hayhauler pictures would help. There should be no way that the spring is coming off the rear mount.
1949 Chevy 6400
1931 Chevy Firetruck
I will try to get pictures this weekend. When I get home from work it is dark. I guess I should have given for details. It is only on leaf that pops up on top of the mount the larger bottom peice stays on. It makes the left side sag and I am concered about damage.
Do you have a broken main leaf?
Picture will help.
Grigg
Yep, It sounds like a broken main leaf. I had one break on a '52 3100. I did't notice it until I put it on the lift one day and the left front wheel was hanging down a lot farther then the right. The second leaf will support the truck when it's on the ground.
1949 Chevy 6400
Where can I get a new set of leaf springs?
I have been in this vendors store, stacks and stacks of springs, parts, more parts, and more parts, all are susposed to be NOS. Try calling never hurts to ask. This vendor is in the links page, I have no affilation. http://www.antiqueautosupply.com/
Brad
Here is a website with pictures of my truck and the leaf spring that is off http://photobucket.com/49hayhauler
I can not see any broken springs. Should I just change it out for a new one anyway? How much do these springs run???
