3 members (JW51, Peggy M, 1 invisible),
63
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I'm at a loss to figure out why the 350 in my 53 3100 is hard to start when its hot. It's not over heating, about 190, but acts like its coming up on compression "turns over slow". I've tried to retard the timing but it don't seem to help. The 350 does have a lumpy cam, don't know what the duration is. Never a problem when its cold. Battery is charged and cables are clean/tight. Thanks, in advance. Hey just wanted thank everyone for thier input, I never would have figured it out, until the starter gave up.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | starter is getting too hot - prolly be best to replace it cuz you'll do better with the heaviest duty version, but also really need to shield it from the exhaust there .... common problem
Bill | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I agree with Red, ya need a heat shiled for the starter. | | | | | Joined: Jan 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 47 | I had the same problem, fixed it with a heat shield from summit racing looks like header wrap part# SUM-350108. Also make sure positive cable is insulated from exhaust heat . GOOD LUCK. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | starter shield and battery contactor trick required.
| | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | I had a similar problem with my 350 in my 49 Chevy car. My battery was mounted in my trunk. It would not start when hot, but started great cold. I tried the wrap around heat shield (be careful not to let it touch the hot wires tot he starter when you wrap it around there. It did not work. I fabricated a shield that clamped to the exhaust pipe to shield the started, did not fix it. I found a kit that Painless wiring offers for Chevy "hot start" problems. It basically just adds a F@$$d solenoid between the battery and starter. This has worked like a champ for many years. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kevin, I have seen and heard about this Painless 'hot start' kit and must admit, I sure don't understand the technology behind it. Why adding a Ford type solenoid between your battery and starter made your rig start easier is beyond me...but you say it works so I'll take your word for it. Stuart | | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | Do not ask me to explain it. I do not understand why either. That is why I am a mechanical engineer and not an electrical engineer. I actually went to my local FLAPS and talked to the old streetrodder there. He gave me a wiring diagram and sold me the Ford solenoid for a few bucks. I did not actually buy the kit from Painless.
I still have the wiring diagram if you need it. But you can Google "hot start" and "Chevy" and come up with it. | | |
