| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I installed a rebuilt fresh air heater in my '49 half ton. Everything is working well. As you know, the heater motor penetrates through the firewall and is visible from inside the engine compartment. My question... is there supposed to be a doughnut-shaped gasket or a housing of some sort that fits around the motor from the engine side? What is it made of and what does it look like. Where can I find one? I don't believe I've seen such a thing for sale by vendors or e-Bay. The motor is not centered in the firewall hole, and it looks a bit funny from the engine side. Thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There was a rubber seal attached to a metal ring that was screwed to the firewall. The motor projected through the seal. The motor should be close to centered in the hole in the dash. I think this has what you are looking for. I would call them to be sure that the large round seal is right. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tim pointed out the gasket set if you want to order it. But I would just cut it out of a sheet of 1/16" rubber, maybe even an old inner tube. it is 4.75"od x 3.125"id or a tight fit to the motor. The metal retainer ring is 1/16"tk x 4.75"od x 3.75"id. it is retained by three clutch head screws from the engine side. Denny Graham Sandwich, IL
Denny G Sandwich, IL
