6 members (Gray_Ghost, cmayna, 46 Texaco, rfs56trk, Hawkman, Wally / Montana), 109 guests, and 3 robots.
Topics128,128
Posts1,056,687
Members48,452
I was wondering if anyone else had this problem and what they did about it. I have the dog house off the front of my '42 half ton, I installed new leaf springs and bushings, and replaced the ball studs on the steering arm and on the pitman arm with ones that are threaded, as opposed to the original pressed in style. Even with the engine and trans in place, the steering arm connection to the draglink hits the front axle. Do I heat the steering arm and bend it up to clear? I can't find any issues with my assembly work. Thanks for your help
Bryan Bauman
I had to loosen the mounting bolts that hold the arm to the spindle and lift it up to clear the axle. There is some wiggle room in the bolt holes. You might also have to grind a little off the bottom of the stud for clearance. Joe
Thanks Joe H, I'll try out both ideas. How much is enough clearance? A quarter inch? Or more like an inch? Will the suspension load up when it hits a bump and contact it?
Bryan Bauman
Mine is less then 1/8" ! As long as it clears, and as long as the king pins are tight, it should never hit. You could smooth up the axle if it has rough casting in that spot. Joe
Wow, that's close, but if it works, what the hey.
Thanks again Joe.
Bryan Bauman
Jim & Caroline
