1 members (Gray_Ghost),
77
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 23 New Guy | | New Guy Joined: Mar 2004 Posts: 23 | I was wondering if anyone else had this problem and what they did about it. I have the dog house off the front of my '42 half ton, I installed new leaf springs and bushings, and replaced the ball studs on the steering arm and on the pitman arm with ones that are threaded, as opposed to the original pressed in style. Even with the engine and trans in place, the steering arm connection to the draglink hits the front axle. Do I heat the steering arm and bend it up to clear? I can't find any issues with my assembly work. Thanks for your help
Bryan Bauman
| | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | I had to loosen the mounting bolts that hold the arm to the spindle and lift it up to clear the axle. There is some wiggle room in the bolt holes. You might also have to grind a little off the bottom of the stud for clearance. Joe | | | | | Joined: Mar 2004 Posts: 23 New Guy | | New Guy Joined: Mar 2004 Posts: 23 | Thanks Joe H, I'll try out both ideas. How much is enough clearance? A quarter inch? Or more like an inch? Will the suspension load up when it hits a bump and contact it?
Bryan Bauman
| | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | Mine is less then 1/8" ! As long as it clears, and as long as the king pins are tight, it should never hit. You could smooth up the axle if it has rough casting in that spot. Joe | | | | | Joined: Mar 2004 Posts: 23 New Guy | | New Guy Joined: Mar 2004 Posts: 23 | Wow, that's close, but if it works, what the hey. Thanks again Joe.
Bryan Bauman
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
