0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 14 New Guy | | New Guy Joined: Dec 2006 Posts: 14 | I need external oil filter lines for a chevy 261. I bought new ones from Jim Carters, but the ones I got are 1/4" grease gun hose and are way too small. The originals are 5/8". I have tried every equipment and tractor repair shop in town and no one can make new. Any ideas on a source for new or used? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What are the sises of the holes in your block?
I think the by-pass filter lines were 1/8" NPT; and. I think the 1957 261s should have a by-pass oil filter. The 1958-1962 261 full-flow filer lines are 1/2" NPT.
When you say 5/8" lines, what are you measuring?
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Any hydraulic hose shop should be able to make those hoses for you. Do you have the old ones they can copy? | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Roy is correct. i had mine made locally in a hydralic shop. They had the stuff already in stock so it was in and out with the lines and connections. 1/2" is the correct size. Here are the photos if that helps: http://rides.webshots.com/photo/2587806810080243953dZeZCu | | | | | Joined: Dec 2006 Posts: 14 New Guy | | New Guy Joined: Dec 2006 Posts: 14 | You guys are right, the hoses are 1/2". The block has galvanized plumbing fittings in it. I have taken them ( the hoses) to every local hydraulic and equipment repair shop in Springfield with no luck. I removed the plumbing fittings and the oddball adapters. Instead of trying to reproduce the cobbled up junk I had, I think I will do what Virginiafiretruck's picture has with longer hoses that run directly to the block.
Thank You | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Wish I were closer, I could build them for you where I work. Our parts store makes some of the wierdest hoses. Have to get a little inventive sometimes. | | |
