5 members (2-Ton, rfs56trk, J Lucas, Pete O, Barry Martak), 84 guests, and 2 robots.
Topics128,094
Posts1,056,489
Members48,444
#499868 01/31/2009 3:20 AM
I need external oil filter lines for a chevy 261. I bought new ones from Jim Carters, but the ones I got are 1/4" grease gun hose and are way too small. The originals are 5/8". I have tried every equipment and tractor repair shop in town and no one can make new. Any ideas on a source for new or used?
What are the sises of the holes in your block?
I think the by-pass filter lines were 1/8" NPT; and. I think the 1957 261s should have a by-pass oil filter. The 1958-1962 261 full-flow filer lines are 1/2" NPT.
When you say 5/8" lines, what are you measuring?
Any hydraulic hose shop should be able to make those hoses for you. Do you have the old ones they can copy?
V
V Offline
Roy is correct. i had mine made locally in a hydralic shop. They had the stuff already in stock so it was in and out with the lines and connections. 1/2" is the correct size. Here are the photos if that helps: http://rides.webshots.com/photo/2587806810080243953dZeZCu
You guys are right, the hoses are 1/2". The block has galvanized plumbing fittings in it. I have taken them ( the hoses) to every local hydraulic and equipment repair shop in Springfield with no luck. I removed the plumbing fittings and the oddball adapters. Instead of trying to reproduce the cobbled up junk I had, I think I will do what Virginiafiretruck's picture has with longer hoses that run directly to the block.
Thank You
Wish I were closer, I could build them for you where I work. Our parts store makes some of the wierdest hoses. Have to get a little inventive sometimes.
