2 members (mo2cyl, Rusty Heaps),
59
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49941 09/09/2005 1:00 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Since I bought my 55.1 the steering column has been off center where it goes through the fire wall. Last nite I tried to adjust it with the dash clamp, but it did not cooperate. How can I get it in the center of the hole in the floor?
Thanks - Scott
55 1st Chev.
#49942 09/09/2005 2:32 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | buy a truck that wasn't originally mass produced, bottom of the line consumer goods w/ poor fit and finish? or move the cab back where it belongs Bill | | |
#49943 09/09/2005 9:43 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Check the cab mounts. They might be sagged or the floor might be rusted or broken. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#49944 09/12/2005 1:04 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks for the tip and the smart remarks!
- Scott
55 1st Chev.
#49945 09/12/2005 8:38 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | red58 has a point - our trucks were built for work, on an assembly line. The fit and finish varies between iffy and awful. Not that that is surprising from GM...Corvettes are essentially handbuilt, and even they've had issues since the start of the line. | | |
#49946 09/13/2005 5:00 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Scott - I would look at how the steering box is mounted. It might be possible to move the mounting of the box one way or the other slightly. I have a 37 and just last weekend I moved the steering box 1/4" toward the engine which helped the centering of the column in the toe floor board and also moved the pitman arm slightly in closer to the frame, achieving two things that I wanted to do. A couple of washers used as spacers might work, depending on which way you are trying to go. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
