2 members (carbking, TUTS 59), 108 guests, and 2 robots.
Topics128,029
Posts1,055,416
Members48,422
#49941 09/09/2005 1:00 PM
Since I bought my 55.1 the steering column has been off center where it goes through the fire wall. Last nite I tried to adjust it with the dash clamp, but it did not cooperate. How can I get it in the center of the hole in the floor?
Thanks - Scott
55 1st Chev.
buy a truck that wasn't originally mass produced, bottom of the line consumer goods w/ poor fit and finish?
or move the cab back where it belongs grin
Riding in the Passing Lane
Check the cab mounts. They might be sagged or the floor might be rusted or broken.
1972 Chevy c10 Cheyenne Super
Thanks for the tip and the smart remarks!
- Scott
55 1st Chev.
red58 has a point - our trucks were built for work, on an assembly line. The fit and finish varies between iffy and awful. Not that that is surprising from GM...Corvettes are essentially handbuilt, and even they've had issues since the start of the line.
1954 GMC De Luxe COE
Scott -
I would look at how the steering box is mounted. It might be possible to move the mounting of the box one way or the other slightly.
I have a 37 and just last weekend I moved the steering box 1/4" toward the engine which helped the centering of the column in the toe floor board and also moved the pitman arm slightly in closer to the frame, achieving two things that I wanted to do.
A couple of washers used as spacers might work, depending on which way you are trying to go.
Joe smile
